Time Before: 0.00158 seconds
Time After: 0.00213 seconds
Time Taken: 0.00055 seconds
Time Before: 0.00220 seconds
Time After: 0.00257 seconds
Time Before: 0.00279 seconds
Time After: 0.00295 seconds
Time Before: 0.00366 seconds
Time After: 0.00590 seconds
Time Taken: 0.00223 seconds
Time Before: 0.00300 seconds
Time After: 0.00933 seconds
Time Taken: 0.00633 seconds
Time Before: 0.01177 seconds
Time After: 0.01219 seconds
Time Before: 0.01464 seconds
Time After: 0.01583 seconds
Time Before: 0.01112 seconds
Time After: 0.01604 seconds
Time Taken: 0.00492 seconds
Time Before: 0.02103 seconds
Time After: 0.02114 seconds
Time Before: 0.02305 seconds
Time After: 0.02425 seconds
End call of global.php: 0.025869131088257
Time Before: 0.02705 seconds
Time After: 0.02720 seconds
Time Before: 0.02951 seconds
Time After: 0.03097 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=139506', badlocation = 1
Time Before: 0.04482 seconds
Time After: 0.04529 seconds
Memory Before: 4,288.977 KB
Memory After: 4,289.203 KB
Page generated in 0.043883085250854 seconds with 9 queries, spending 0.0077676773071289 doing MySQL queries and 0.036115407943726 doing PHP things.
