Time Before: 0.00718 seconds
Time After: 0.00955 seconds
Time Taken: 0.00238 seconds
Time Before: 0.00966 seconds
Time After: 0.01010 seconds
Time Before: 0.01033 seconds
Time After: 0.01048 seconds
Time Before: 0.01125 seconds
Time After: 0.01379 seconds
Time Taken: 0.00254 seconds
Time Before: 0.01054 seconds
Time After: 0.01735 seconds
Time Taken: 0.00681 seconds
Time Before: 0.02215 seconds
Time After: 0.02257 seconds
Time Before: 0.02397 seconds
Time After: 0.02518 seconds
Memory Before: 2,148.953 KB
Memory After: 2,148.813 KB
Time Before: 0.02148 seconds
Time After: 0.02539 seconds
Time Taken: 0.00392 seconds
Memory After: 2,261.836 KB
Time Before: 0.04113 seconds
Time After: 0.04130 seconds
Memory Before: 2,815.359 KB
Memory After: 2,815.875 KB
Time Before: 0.05154 seconds
Time After: 0.05371 seconds
Time Taken: 0.00216 seconds
Memory Before: 2,903.570 KB
Memory After: 2,904.164 KB
End call of global.php: 0.055459022521973
Time Before: 0.05848 seconds
Time After: 0.05865 seconds
Memory Before: 3,540.344 KB
Memory After: 3,540.773 KB
Time Before: 0.06101 seconds
Time After: 0.06248 seconds
Memory Before: 3,821.906 KB
Memory After: 3,823.594 KB
SET lastactivity = 1789110555, location = '/forums/private.php?do=newpm&explain=1&u=13966', badlocation = 1
Time Before: 0.07670 seconds
Time After: 0.07702 seconds
Memory Before: 4,287.859 KB
Memory After: 4,288.070 KB
Page generated in 0.075796842575073 seconds with 9 queries, spending 0.0090508460998535 doing MySQL queries and 0.06674599647522 doing PHP things.
