Time Before: 0.02416 seconds
Time After: 0.02978 seconds
Time Taken: 0.00562 seconds
Time Before: 0.02987 seconds
Time After: 0.03028 seconds
Time Before: 0.03068 seconds
Time After: 0.03097 seconds
Time Before: 0.03189 seconds
Time After: 0.03377 seconds
Time Taken: 0.00187 seconds
Time Before: 0.03103 seconds
Time After: 0.04019 seconds
Time Taken: 0.00916 seconds
Time Before: 0.04806 seconds
Time After: 0.04835 seconds
Time Before: 0.05032 seconds
Time After: 0.05160 seconds
Time Before: 0.04735 seconds
Time After: 0.05186 seconds
Time Taken: 0.00450 seconds
Time Before: 0.09697 seconds
Time After: 0.09711 seconds
Time Before: 0.11860 seconds
Time After: 0.11984 seconds
End call of global.php: 0.12212491035461
Time Before: 0.13143 seconds
Time After: 0.13161 seconds
Time Before: 0.13439 seconds
Time After: 0.13678 seconds
Time Taken: 0.00239 seconds
SET lastactivity = 1776723660, location = '/forums/private.php?do=newpm&explain=1&u=139708', badlocation = 1
Time Before: 0.15665 seconds
Time After: 0.15693 seconds
Memory Before: 4,288.547 KB
Memory After: 4,288.758 KB
Page generated in 0.1556990146637 seconds with 9 queries, spending 0.0083630084991455 doing MySQL queries and 0.14733600616455 doing PHP things.
