Time Before: 0.00143 seconds
Time After: 0.00207 seconds
Time Taken: 0.00064 seconds
Time Before: 0.00214 seconds
Time After: 0.00270 seconds
Time Taken: 0.00056 seconds
Time Before: 0.00290 seconds
Time After: 0.00306 seconds
Time Before: 0.00373 seconds
Time After: 0.00635 seconds
Time Taken: 0.00262 seconds
Time Before: 0.00311 seconds
Time After: 0.00972 seconds
Time Taken: 0.00662 seconds
Time Before: 0.01172 seconds
Time After: 0.01217 seconds
Time Before: 0.01453 seconds
Time After: 0.01577 seconds
Time Before: 0.01106 seconds
Time After: 0.01594 seconds
Time Taken: 0.00488 seconds
Time Before: 0.02095 seconds
Time After: 0.02117 seconds
Time Before: 0.02349 seconds
Time After: 0.02481 seconds
Time Taken: 0.00132 seconds
End call of global.php: 0.026411056518555
Time Before: 0.02776 seconds
Time After: 0.02799 seconds
Time Before: 0.03008 seconds
Time After: 0.03156 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=139714'
Time Before: 0.04413 seconds
Time After: 0.04439 seconds
Memory Before: 4,287.922 KB
Memory After: 4,288.164 KB
Page generated in 0.043239116668701 seconds with 9 queries, spending 0.0085413455963135 doing MySQL queries and 0.034697771072388 doing PHP things.
