Time Before: 0.00150 seconds
Time After: 0.00206 seconds
Time Taken: 0.00056 seconds
Time Before: 0.00213 seconds
Time After: 0.00266 seconds
Time Taken: 0.00053 seconds
Time Before: 0.00294 seconds
Time After: 0.00313 seconds
Time Before: 0.00379 seconds
Time After: 0.00627 seconds
Time Taken: 0.00248 seconds
Time Before: 0.00319 seconds
Time After: 0.00963 seconds
Time Taken: 0.00644 seconds
Time Before: 0.01153 seconds
Time After: 0.01193 seconds
Time Before: 0.01429 seconds
Time After: 0.01567 seconds
Time Taken: 0.00137 seconds
Time Before: 0.01088 seconds
Time After: 0.01584 seconds
Time Taken: 0.00495 seconds
Time Before: 0.02088 seconds
Time After: 0.02102 seconds
Time Before: 0.02292 seconds
Time After: 0.02422 seconds
End call of global.php: 0.025850057601929
Time Before: 0.02715 seconds
Time After: 0.02734 seconds
Time Before: 0.02929 seconds
Time After: 0.03077 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=139918', badlocation = 1
Time Before: 0.04394 seconds
Time After: 0.04432 seconds
Memory Before: 4,288.203 KB
Memory After: 4,288.430 KB
Page generated in 0.043000936508179 seconds with 9 queries, spending 0.0084488391876221 doing MySQL queries and 0.034552097320557 doing PHP things.
