Time Before: 0.00151 seconds
Time After: 0.00213 seconds
Time Taken: 0.00062 seconds
Time Before: 0.00219 seconds
Time After: 0.00264 seconds
Time Before: 0.00289 seconds
Time After: 0.00301 seconds
Time Before: 0.00377 seconds
Time After: 0.00614 seconds
Time Taken: 0.00236 seconds
Time Before: 0.00309 seconds
Time After: 0.01092 seconds
Time Taken: 0.00783 seconds
Time Before: 0.01323 seconds
Time After: 0.01363 seconds
Time Before: 0.01668 seconds
Time After: 0.01807 seconds
Time Taken: 0.00139 seconds
Time Before: 0.01249 seconds
Time After: 0.01831 seconds
Time Taken: 0.00583 seconds
Time Before: 0.02475 seconds
Time After: 0.02493 seconds
Time Before: 0.02725 seconds
Time After: 0.02864 seconds
End call of global.php: 0.031203985214233
Time Before: 0.03257 seconds
Time After: 0.03272 seconds
Time Before: 0.03585 seconds
Time After: 0.03740 seconds
Time Taken: 0.00154 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=140017', badlocation = 1
WHERE sessionhash = '1b43d45bbaaa70ba8be59b846adc9cfa'
Time Before: 0.05130 seconds
Time After: 0.05157 seconds
Page generated in 0.050370931625366 seconds with 9 queries, spending 0.0082404613494873 doing MySQL queries and 0.042130470275879 doing PHP things.
