Time Before: 0.02323 seconds
Time After: 0.03445 seconds
Time Taken: 0.01122 seconds
Time Before: 0.03457 seconds
Time After: 0.03512 seconds
Time Taken: 0.00055 seconds
Time Before: 0.03538 seconds
Time After: 0.03551 seconds
Time Before: 0.03634 seconds
Time After: 0.03845 seconds
Time Taken: 0.00211 seconds
Time Before: 0.03558 seconds
Time After: 0.04242 seconds
Time Taken: 0.00684 seconds
Time Before: 0.04914 seconds
Time After: 0.04948 seconds
Time Before: 0.05087 seconds
Time After: 0.05224 seconds
Time Taken: 0.00137 seconds
Memory Before: 2,148.836 KB
Memory After: 2,148.695 KB
Time Before: 0.04846 seconds
Time After: 0.05250 seconds
Time Taken: 0.00404 seconds
Memory After: 2,261.719 KB
Time Before: 0.09048 seconds
Time After: 0.09063 seconds
Memory Before: 2,815.297 KB
Memory After: 2,815.813 KB
Time Before: 0.11414 seconds
Time After: 0.11558 seconds
Memory Before: 2,903.500 KB
Memory After: 2,904.094 KB
End call of global.php: 0.11795997619629
Time Before: 0.12795 seconds
Time After: 0.12811 seconds
Memory Before: 3,540.289 KB
Memory After: 3,540.719 KB
Time Before: 0.13103 seconds
Time After: 0.13246 seconds
Memory Before: 3,821.844 KB
Memory After: 3,823.531 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=14004', badlocation = 1
Time Before: 0.15114 seconds
Time After: 0.15857 seconds
Time Taken: 0.00743 seconds
Memory Before: 4,287.500 KB
Memory After: 4,287.727 KB
Page generated in 0.1500678062439 seconds with 9 queries, spending 0.015093803405762 doing MySQL queries and 0.13497400283813 doing PHP things.
