Time Before: 0.02436 seconds
Time After: 0.03306 seconds
Time Taken: 0.00870 seconds
Time Before: 0.03317 seconds
Time After: 0.03378 seconds
Time Taken: 0.00061 seconds
Time Before: 0.03403 seconds
Time After: 0.03418 seconds
Time Before: 0.03506 seconds
Time After: 0.03718 seconds
Time Taken: 0.00212 seconds
Time Before: 0.03426 seconds
Time After: 0.04200 seconds
Time Taken: 0.00775 seconds
Time Before: 0.05212 seconds
Time After: 0.05252 seconds
Time Before: 0.05499 seconds
Time After: 0.05630 seconds
Time Taken: 0.00131 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.05143 seconds
Time After: 0.05655 seconds
Time Taken: 0.00512 seconds
Memory After: 2,261.820 KB
Time Before: 0.08741 seconds
Time After: 0.08755 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.10835 seconds
Time After: 0.10980 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
Time Before: 0.12675 seconds
Time After: 0.12721 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.13026 seconds
Time After: 0.13171 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
UPDATE session SET lastactivity = 1789109831, location = '/forums/private.php?do=newpm&explain=1&u=140086' WHERE sessionhash = 'fead92432b1d1f7bb19e50f71f2f4484'
Time Before: 0.14837 seconds
Time After: 0.15311 seconds
Time Taken: 0.00474 seconds
Memory Before: 4,287.563 KB
Memory After: 4,287.781 KB
