Time Before: 0.01543 seconds
Time After: 0.01945 seconds
Time Taken: 0.00403 seconds
Time Before: 0.01954 seconds
Time After: 0.02009 seconds
Time Taken: 0.00055 seconds
Time Before: 0.02043 seconds
Time After: 0.02083 seconds
Time Before: 0.02170 seconds
Time After: 0.02410 seconds
Time Taken: 0.00240 seconds
Time Before: 0.02091 seconds
Time After: 0.02797 seconds
Time Taken: 0.00707 seconds
Time Before: 0.03814 seconds
Time After: 0.03836 seconds
Time Before: 0.04140 seconds
Time After: 0.04266 seconds
Time Before: 0.03745 seconds
Time After: 0.04288 seconds
Time Taken: 0.00543 seconds
Time Before: 0.06780 seconds
Time After: 0.06794 seconds
Time Before: 0.29240 seconds
Time After: 0.29374 seconds
Time Taken: 0.00134 seconds
Time Before: 0.30629 seconds
Time After: 0.30645 seconds
Time Before: 0.30889 seconds
Time After: 0.31035 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=140098', badlocation = 1 WHERE sessionhash = 'cb23636bbd36247f3b1133fdf383bca3'
Time Before: 0.33120 seconds
Time After: 0.33148 seconds
Memory Before: 4,911.867 KB
Memory After: 4,912.094 KB
