Time Before: 0.00443 seconds
Time After: 0.00693 seconds
Time Taken: 0.00250 seconds
Time Before: 0.00704 seconds
Time After: 0.00742 seconds
Time Before: 0.00764 seconds
Time After: 0.00776 seconds
Time Before: 0.00843 seconds
Time After: 0.01117 seconds
Time Taken: 0.00274 seconds
Time Before: 0.00780 seconds
Time After: 0.01649 seconds
Time Taken: 0.00868 seconds
Time Before: 0.02067 seconds
Time After: 0.02106 seconds
Time Before: 0.02392 seconds
Time After: 0.02520 seconds
Time Before: 0.01995 seconds
Time After: 0.02544 seconds
Time Taken: 0.00549 seconds
Time Before: 0.03356 seconds
Time After: 0.03372 seconds
Time Before: 0.03943 seconds
Time After: 0.04068 seconds
Time Before: 0.04436 seconds
Time After: 0.04453 seconds
Time Before: 0.04686 seconds
Time After: 0.04829 seconds
UPDATE session SET lastactivity = 1776619971, location = '/forums/private.php?do=newpm&explain=1&u=140112' WHERE sessionhash = '0072f2714e5608fd7a8a8d7024a3e041'
Time Before: 0.06134 seconds
Time After: 0.06169 seconds
