Time Before: 0.00276 seconds
Time After: 0.00357 seconds
Time Taken: 0.00081 seconds
Memory Before: 1,246.250 KB
Memory After: 1,273.055 KB
Time Before: 0.00366 seconds
Time After: 0.00409 seconds
Memory Before: 1,273.016 KB
Memory After: 1,273.992 KB
Time Before: 0.00431 seconds
Time After: 0.00446 seconds
Memory Before: 1,274.633 KB
Memory After: 1,275.156 KB
Time Before: 0.00515 seconds
Time After: 0.00863 seconds
Time Taken: 0.00349 seconds
Memory Before: 1,278.023 KB
Memory After: 1,278.945 KB
Time Before: 0.00451 seconds
Time After: 0.01290 seconds
Time Taken: 0.00839 seconds
Memory Before: 1,274.438 KB
Memory After: 2,355.672 KB
Memory Used: 1,081.234 KB
Time Before: 0.01624 seconds
Time After: 0.01644 seconds
Memory Before: 2,895.938 KB
Memory After: 2,896.555 KB
Time Before: 0.01929 seconds
Time After: 0.02262 seconds
Time Taken: 0.00333 seconds
Memory Before: 2,908.383 KB
Memory After: 2,908.242 KB
Time Before: 0.01546 seconds
Time After: 0.02287 seconds
Time Taken: 0.00741 seconds
Memory Before: 2,888.664 KB
Memory After: 3,021.297 KB
Memory Used: 132.633 KB
Time Before: 0.03568 seconds
Time After: 0.03588 seconds
Memory Before: 3,655.813 KB
Memory After: 3,656.328 KB
Time Before: 0.04340 seconds
Time After: 0.04467 seconds
Memory Before: 4,133.500 KB
Memory After: 4,134.094 KB
End call of global.php: 0.046383857727051
Time Before: 0.05306 seconds
Time After: 0.05388 seconds
Time Taken: 0.00082 seconds
Memory Before: 5,197.727 KB
Memory After: 5,326.070 KB
Time Before: 0.05620 seconds
Time After: 0.05876 seconds
Time Taken: 0.00256 seconds
Memory Before: 5,481.406 KB
Memory After: 5,611.008 KB
SET lastactivity = 1768765795, location = '/forums/private.php?do=newpm&explain=1&u=140114', badlocation = 1
WHERE sessionhash = '493329e92668bdfe23f60c8f4163b3e0'
Time Before: 0.07588 seconds
Time After: 0.07612 seconds
Memory Before: 5,998.219 KB
Memory After: 5,998.430 KB
Page generated in 0.07459282875061 seconds with 9 queries, spending 0.012685775756836 doing MySQL queries and 0.061907052993774 doing PHP things.
