Time Before: 0.00147 seconds
Time After: 0.00206 seconds
Time Taken: 0.00060 seconds
Time Before: 0.00216 seconds
Time After: 0.00262 seconds
Time Before: 0.00290 seconds
Time After: 0.00304 seconds
Time Before: 0.00375 seconds
Time After: 0.00605 seconds
Time Taken: 0.00230 seconds
Time Before: 0.00309 seconds
Time After: 0.01072 seconds
Time Taken: 0.00762 seconds
Time Before: 0.01342 seconds
Time After: 0.01383 seconds
Time Before: 0.01698 seconds
Time After: 0.01816 seconds
Time Taken: 0.00118 seconds
Time Before: 0.01239 seconds
Time After: 0.01839 seconds
Time Taken: 0.00600 seconds
Time Before: 0.02517 seconds
Time After: 0.02530 seconds
Time Before: 0.02739 seconds
Time After: 0.02863 seconds
End call of global.php: 0.030614137649536
Time Before: 0.03185 seconds
Time After: 0.03201 seconds
Time Before: 0.03450 seconds
Time After: 0.03600 seconds
Time Taken: 0.00150 seconds
SET lastactivity = 1783067283, location = '/forums/private.php?do=newpm&explain=1&u=140168', badlocation = 1
Time Before: 0.05213 seconds
Time After: 0.05249 seconds
Memory Before: 4,288.547 KB
Memory After: 4,288.758 KB
Page generated in 0.051221132278442 seconds with 9 queries, spending 0.0078699588775635 doing MySQL queries and 0.043351173400879 doing PHP things.
