Time Before: 0.02328 seconds
Time After: 0.03144 seconds
Time Taken: 0.00816 seconds
Memory Before: 1,246.250 KB
Memory After: 1,273.055 KB
Time Before: 0.03157 seconds
Time After: 0.03198 seconds
Memory Before: 1,273.016 KB
Memory After: 1,273.992 KB
Time Before: 0.03227 seconds
Time After: 0.03242 seconds
Memory Before: 1,274.633 KB
Memory After: 1,275.156 KB
Time Before: 0.03336 seconds
Time After: 0.03595 seconds
Time Taken: 0.00259 seconds
Memory Before: 1,278.023 KB
Memory After: 1,278.945 KB
Time Before: 0.03252 seconds
Time After: 0.04062 seconds
Time Taken: 0.00810 seconds
Memory Before: 1,274.438 KB
Memory After: 2,355.672 KB
Memory Used: 1,081.234 KB
Time Before: 0.04920 seconds
Time After: 0.04970 seconds
Memory Before: 2,895.938 KB
Memory After: 2,896.555 KB
Time Before: 0.05302 seconds
Time After: 0.05449 seconds
Memory Before: 2,908.266 KB
Memory After: 2,908.125 KB
Time Before: 0.04816 seconds
Time After: 0.05472 seconds
Time Taken: 0.00656 seconds
Memory Before: 2,888.664 KB
Memory After: 3,021.180 KB
Memory Used: 132.516 KB
Time Before: 0.09245 seconds
Time After: 0.09259 seconds
Memory Before: 3,655.820 KB
Memory After: 3,656.336 KB
Time Before: 0.13084 seconds
Time After: 0.13206 seconds
Memory Before: 4,133.383 KB
Memory After: 4,133.977 KB
Time Before: 0.16597 seconds
Time After: 0.16616 seconds
Memory Before: 5,197.555 KB
Memory After: 5,325.898 KB
Time Before: 0.17272 seconds
Time After: 0.17422 seconds
Time Taken: 0.00150 seconds
Memory Before: 5,481.250 KB
Memory After: 5,610.852 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=140208', badlocation = 1 WHERE sessionhash = '05469e5b46550d3cbf9ccd27256b5c39'
Time Before: 0.19266 seconds
Time After: 0.19293 seconds
Memory Before: 5,997.836 KB
Memory After: 5,998.055 KB
