Time Before: 0.00170 seconds
Time After: 0.00248 seconds
Time Taken: 0.00077 seconds
Time Before: 0.00258 seconds
Time After: 0.00315 seconds
Time Taken: 0.00057 seconds
Time Before: 0.00337 seconds
Time After: 0.00347 seconds
Time Taken: 0.00010 seconds
Time Before: 0.00414 seconds
Time After: 0.00637 seconds
Time Taken: 0.00223 seconds
Time Before: 0.00352 seconds
Time After: 0.00971 seconds
Time Taken: 0.00619 seconds
Time Before: 0.01147 seconds
Time After: 0.01201 seconds
Time Taken: 0.00053 seconds
Time Before: 0.01334 seconds
Time After: 0.01456 seconds
Time Before: 0.01088 seconds
Time After: 0.01473 seconds
Time Taken: 0.00385 seconds
Time Before: 0.01975 seconds
Time After: 0.01997 seconds
Time Before: 0.02192 seconds
Time After: 0.02314 seconds
Time Before: 0.02587 seconds
Time After: 0.02604 seconds
Time Before: 0.02808 seconds
Time After: 0.02966 seconds
Time Taken: 0.00157 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=140222', badlocation = 1 WHERE sessionhash = '7ca6ab718f0d2129a0db1a6bd7e3c55b'
Time Before: 0.04207 seconds
Time After: 0.04235 seconds
Memory Before: 4,288.977 KB
Memory After: 4,289.203 KB
