Time Before: 0.02397 seconds
Time After: 0.03186 seconds
Time Taken: 0.00789 seconds
Time Before: 0.03198 seconds
Time After: 0.03257 seconds
Time Taken: 0.00059 seconds
Time Before: 0.03288 seconds
Time After: 0.03306 seconds
Time Before: 0.03383 seconds
Time After: 0.03617 seconds
Time Taken: 0.00234 seconds
Time Before: 0.03314 seconds
Time After: 0.04068 seconds
Time Taken: 0.00754 seconds
Time Before: 0.04673 seconds
Time After: 0.04721 seconds
Time Before: 0.04863 seconds
Time After: 0.04982 seconds
Time Before: 0.04600 seconds
Time After: 0.05008 seconds
Time Taken: 0.00408 seconds
Time Before: 0.08771 seconds
Time After: 0.08789 seconds
Time Before: 0.10151 seconds
Time After: 0.10283 seconds
Time Taken: 0.00132 seconds
End call of global.php: 0.10501909255981
Time Before: 0.11312 seconds
Time After: 0.11334 seconds
Time Before: 0.11620 seconds
Time After: 0.11772 seconds
Time Taken: 0.00151 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=140311'
Time Before: 0.13668 seconds
Time After: 0.13697 seconds
Page generated in 0.13556313514709 seconds with 9 queries, spending 0.008317232131958 doing MySQL queries and 0.12724590301514 doing PHP things.
