Time Before: 0.01938 seconds
Time After: 0.02762 seconds
Time Taken: 0.00823 seconds
Time Before: 0.02771 seconds
Time After: 0.02820 seconds
Time Before: 0.02848 seconds
Time After: 0.02862 seconds
Time Before: 0.02942 seconds
Time After: 0.03132 seconds
Time Taken: 0.00189 seconds
Time Before: 0.02869 seconds
Time After: 0.03584 seconds
Time Taken: 0.00715 seconds
Time Before: 0.04315 seconds
Time After: 0.04349 seconds
Time Before: 0.04537 seconds
Time After: 0.04742 seconds
Time Taken: 0.00205 seconds
Time Before: 0.04247 seconds
Time After: 0.04763 seconds
Time Taken: 0.00516 seconds
Time Before: 0.10216 seconds
Time After: 0.10230 seconds
Time Before: 0.29889 seconds
Time After: 0.30026 seconds
Time Taken: 0.00137 seconds
Time Before: 0.31243 seconds
Time After: 0.31262 seconds
Time Before: 0.31625 seconds
Time After: 0.31775 seconds
Time Taken: 0.00150 seconds
UPDATE session SET lastactivity = 1789147837, location = '/forums/private.php?do=newpm&explain=1&u=140336' WHERE sessionhash = '2e9a27470c1bd6d04caedfc611bd3cf4'
Time Before: 0.33883 seconds
Time After: 0.33917 seconds
