Time Before: 0.01146 seconds
Time After: 0.01555 seconds
Time Taken: 0.00409 seconds
Time Before: 0.01564 seconds
Time After: 0.01599 seconds
Time Before: 0.01621 seconds
Time After: 0.01632 seconds
Time Before: 0.01706 seconds
Time After: 0.01936 seconds
Time Taken: 0.00230 seconds
Time Before: 0.01638 seconds
Time After: 0.02363 seconds
Time Taken: 0.00726 seconds
Time Before: 0.02932 seconds
Time After: 0.02972 seconds
Time Before: 0.03243 seconds
Time After: 0.03366 seconds
Time Before: 0.02868 seconds
Time After: 0.03389 seconds
Time Taken: 0.00521 seconds
Time Before: 0.05263 seconds
Time After: 0.05276 seconds
Time Before: 0.06435 seconds
Time After: 0.06559 seconds
Time Before: 0.07362 seconds
Time After: 0.07376 seconds
Time Before: 0.07647 seconds
Time After: 0.07805 seconds
Time Taken: 0.00158 seconds
UPDATE session SET lastactivity = 1783094632, location = '/forums/private.php?do=newpm&explain=1&u=140343', badlocation = 1 WHERE sessionhash = '05bc7c79f91873f78083814ccb7adf41'
Time Before: 0.09585 seconds
Time After: 0.09613 seconds
