Time Before: 0.00542 seconds
Time After: 0.00684 seconds
Time Before: 0.00691 seconds
Time After: 0.00729 seconds
Time Before: 0.00752 seconds
Time After: 0.00766 seconds
Time Before: 0.00849 seconds
Time After: 0.01086 seconds
Time Taken: 0.00237 seconds
Time Before: 0.00774 seconds
Time After: 0.01520 seconds
Time Taken: 0.00747 seconds
Time Before: 0.01884 seconds
Time After: 0.01907 seconds
Time Before: 0.02242 seconds
Time After: 0.02410 seconds
Time Taken: 0.00168 seconds
Time Before: 0.01808 seconds
Time After: 0.02432 seconds
Time Taken: 0.00624 seconds
Time Before: 0.03851 seconds
Time After: 0.03864 seconds
Time Before: 0.04380 seconds
Time After: 0.04501 seconds
Time Before: 0.04981 seconds
Time After: 0.04997 seconds
Time Before: 0.05283 seconds
Time After: 0.05431 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=140373', badlocation = 1 WHERE sessionhash = 'b773d1d737f443efcc9fdfe9a9930185'
Time Before: 0.07160 seconds
Time After: 0.07186 seconds
Memory Before: 4,288.203 KB
Memory After: 4,288.430 KB
