Time Before: 0.02435 seconds
Time After: 0.03187 seconds
Time Taken: 0.00752 seconds
Memory Before: 532.883 KB
Memory After: 558.000 KB
Time Before: 0.03199 seconds
Time After: 0.03316 seconds
Time Taken: 0.00117 seconds
Memory Before: 557.938 KB
Memory After: 558.945 KB
Time Before: 0.03338 seconds
Time After: 0.03351 seconds
Memory Before: 559.500 KB
Memory After: 560.023 KB
Time Before: 0.03430 seconds
Time After: 0.03661 seconds
Time Taken: 0.00231 seconds
Memory Before: 562.625 KB
Memory After: 563.547 KB
Time Before: 0.03358 seconds
Time After: 0.04111 seconds
Time Taken: 0.00753 seconds
Memory Before: 559.273 KB
Memory After: 1,640.320 KB
Memory Used: 1,081.047 KB
Time Before: 0.05163 seconds
Time After: 0.05209 seconds
Memory Before: 2,135.250 KB
Memory After: 2,135.867 KB
Time Before: 0.05481 seconds
Time After: 0.05598 seconds
Memory Before: 2,147.414 KB
Memory After: 2,147.273 KB
Time Before: 0.05065 seconds
Time After: 0.05623 seconds
Time Taken: 0.00558 seconds
Memory Before: 2,127.430 KB
Memory After: 2,260.641 KB
Memory Used: 133.211 KB
Time Before: 0.08888 seconds
Time After: 0.08902 seconds
Memory Before: 2,814.180 KB
Memory After: 2,814.695 KB
Time Before: 0.10322 seconds
Time After: 0.10450 seconds
Memory Before: 2,902.500 KB
Memory After: 2,903.094 KB
Time Before: 0.11642 seconds
Time After: 0.11660 seconds
Memory Before: 3,539.297 KB
Memory After: 3,539.727 KB
Time Before: 0.11932 seconds
Time After: 0.12078 seconds
Memory Before: 3,820.828 KB
Memory After: 3,822.516 KB
UPDATE session SET lastactivity = 1785311199, location = '/forums/private.php?do=newpm&explain=1&u=140378' WHERE sessionhash = '5dcfbb55b5add1e7cfb509ae0e835a95'
Time Before: 0.13723 seconds
Time After: 0.13756 seconds
Memory Before: 4,299.156 KB
Memory After: 4,299.383 KB
