Time Before: 0.00725 seconds
Time After: 0.01052 seconds
Time Taken: 0.00327 seconds
Time Before: 0.01062 seconds
Time After: 0.01108 seconds
Time Before: 0.01131 seconds
Time After: 0.01148 seconds
Time Before: 0.01225 seconds
Time After: 0.01467 seconds
Time Taken: 0.00241 seconds
Time Before: 0.01154 seconds
Time After: 0.01908 seconds
Time Taken: 0.00754 seconds
Time Before: 0.02294 seconds
Time After: 0.02339 seconds
Time Before: 0.02603 seconds
Time After: 0.02733 seconds
Time Before: 0.02221 seconds
Time After: 0.02759 seconds
Time Taken: 0.00538 seconds
Time Before: 0.04201 seconds
Time After: 0.04217 seconds
Time Before: 0.05190 seconds
Time After: 0.05313 seconds
End call of global.php: 0.055103778839111
Time Before: 0.05890 seconds
Time After: 0.05912 seconds
Time Before: 0.06142 seconds
Time After: 0.06296 seconds
Time Taken: 0.00154 seconds
SET lastactivity = 1785417119, location = '/forums/private.php?do=newpm&explain=1&u=140384', badlocation = 1
Time Before: 0.08008 seconds
Time After: 0.08034 seconds
Memory Before: 4,288.547 KB
Memory After: 4,288.758 KB
Page generated in 0.078986883163452 seconds with 9 queries, spending 0.0082123279571533 doing MySQL queries and 0.070774555206299 doing PHP things.
