Time Before: 0.00690 seconds
Time After: 0.00796 seconds
Time Taken: 0.00105 seconds
Memory Before: 1,246.250 KB
Memory After: 1,273.055 KB
Time Before: 0.00808 seconds
Time After: 0.00855 seconds
Memory Before: 1,273.016 KB
Memory After: 1,273.992 KB
Time Before: 0.00886 seconds
Time After: 0.00897 seconds
Memory Before: 1,274.633 KB
Memory After: 1,275.156 KB
Time Before: 0.00985 seconds
Time After: 0.01369 seconds
Time Taken: 0.00383 seconds
Memory Before: 1,278.023 KB
Memory After: 1,278.945 KB
Time Before: 0.00905 seconds
Time After: 0.01826 seconds
Time Taken: 0.00921 seconds
Memory Before: 1,274.438 KB
Memory After: 2,355.672 KB
Memory Used: 1,081.234 KB
Time Before: 0.02163 seconds
Time After: 0.02212 seconds
Memory Before: 2,895.938 KB
Memory After: 2,896.555 KB
Time Before: 0.02353 seconds
Time After: 0.02479 seconds
Memory Before: 2,908.383 KB
Memory After: 2,908.242 KB
Time Before: 0.02086 seconds
Time After: 0.02500 seconds
Time Taken: 0.00414 seconds
Memory Before: 2,888.664 KB
Memory After: 3,021.297 KB
Memory Used: 132.633 KB
Time Before: 0.04026 seconds
Time After: 0.04043 seconds
Memory Before: 3,655.813 KB
Memory After: 3,656.328 KB
Time Before: 0.05882 seconds
Time After: 0.06012 seconds
Memory Before: 4,133.500 KB
Memory After: 4,134.094 KB
End call of global.php: 0.062349081039429
Time Before: 0.07279 seconds
Time After: 0.07296 seconds
Memory Before: 5,197.727 KB
Memory After: 5,326.070 KB
Time Before: 0.07560 seconds
Time After: 0.07705 seconds
Memory Before: 5,481.406 KB
Memory After: 5,611.008 KB
SET lastactivity = 1773095843, location = '/forums/private.php?do=newpm&explain=1&u=140394'
WHERE sessionhash = '8385044bee7d6de684cfeaf823df6777'
Time Before: 0.09521 seconds
Time After: 0.09564 seconds
Memory Before: 5,997.945 KB
Memory After: 5,998.164 KB
Page generated in 0.093950986862183 seconds with 9 queries, spending 0.0096876621246338 doing MySQL queries and 0.084263324737549 doing PHP things.
