Time Before: 0.00151 seconds
Time After: 0.00207 seconds
Time Taken: 0.00056 seconds
Time Before: 0.00214 seconds
Time After: 0.00266 seconds
Time Before: 0.00293 seconds
Time After: 0.00307 seconds
Time Before: 0.00399 seconds
Time After: 0.00658 seconds
Time Taken: 0.00258 seconds
Time Before: 0.00315 seconds
Time After: 0.01159 seconds
Time Taken: 0.00844 seconds
Time Before: 0.01352 seconds
Time After: 0.01401 seconds
Time Before: 0.01723 seconds
Time After: 0.01841 seconds
Time Taken: 0.00118 seconds
Time Before: 0.01284 seconds
Time After: 0.01866 seconds
Time Taken: 0.00582 seconds
Time Before: 0.02547 seconds
Time After: 0.02561 seconds
Time Before: 0.02755 seconds
Time After: 0.02877 seconds
Time Before: 0.03190 seconds
Time After: 0.03215 seconds
Time Before: 0.03565 seconds
Time After: 0.03711 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=140409' WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.05017 seconds
Time After: 0.05042 seconds
