Time Before: 0.01992 seconds
Time After: 0.02578 seconds
Time Taken: 0.00586 seconds
Time Before: 0.02588 seconds
Time After: 0.02628 seconds
Time Before: 0.02652 seconds
Time After: 0.02665 seconds
Time Before: 0.02749 seconds
Time After: 0.03003 seconds
Time Taken: 0.00254 seconds
Time Before: 0.02672 seconds
Time After: 0.03477 seconds
Time Taken: 0.00804 seconds
Time Before: 0.04128 seconds
Time After: 0.04170 seconds
Time Before: 0.04469 seconds
Time After: 0.04587 seconds
Time Taken: 0.00118 seconds
Time Before: 0.04058 seconds
Time After: 0.04606 seconds
Time Taken: 0.00549 seconds
Time Before: 0.07691 seconds
Time After: 0.07706 seconds
Time Before: 0.15852 seconds
Time After: 0.15975 seconds
Time Before: 0.17043 seconds
Time After: 0.17063 seconds
Time Before: 0.17292 seconds
Time After: 0.17435 seconds
UPDATE session SET lastactivity = 1777248602, location = '/forums/private.php?do=newpm&explain=1&u=140421', badlocation = 1 WHERE sessionhash = 'e9b85940693e8ec450606894f10508c2'
Time Before: 0.19174 seconds
Time After: 0.19200 seconds
Memory Before: 4,289.344 KB
Memory After: 4,289.555 KB
