Time Before: 0.00158 seconds
Time After: 0.00209 seconds
Time Before: 0.00216 seconds
Time After: 0.00267 seconds
Time Before: 0.00294 seconds
Time After: 0.00313 seconds
Time Before: 0.00398 seconds
Time After: 0.00671 seconds
Time Taken: 0.00273 seconds
Time Before: 0.00320 seconds
Time After: 0.01187 seconds
Time Taken: 0.00867 seconds
Time Before: 0.01375 seconds
Time After: 0.01411 seconds
Time Before: 0.01669 seconds
Time After: 0.01784 seconds
Time Taken: 0.00116 seconds
Time Before: 0.01313 seconds
Time After: 0.01802 seconds
Time Taken: 0.00489 seconds
Time Before: 0.02572 seconds
Time After: 0.02584 seconds
Time Before: 0.02862 seconds
Time After: 0.02989 seconds
End call of global.php: 0.03210186958313
Time Before: 0.03346 seconds
Time After: 0.03361 seconds
Time Before: 0.03655 seconds
Time After: 0.03802 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=140520'
Time Before: 0.05166 seconds
Time After: 0.05191 seconds
Memory Before: 4,287.922 KB
Memory After: 4,288.164 KB
Page generated in 0.050725936889648 seconds with 9 queries, spending 0.008209228515625 doing MySQL queries and 0.042516708374023 doing PHP things.
