Time Before: 0.01148 seconds
Time After: 0.01675 seconds
Time Taken: 0.00527 seconds
Time Before: 0.01687 seconds
Time After: 0.01727 seconds
Time Before: 0.01749 seconds
Time After: 0.01761 seconds
Time Before: 0.01834 seconds
Time After: 0.02065 seconds
Time Taken: 0.00231 seconds
Time Before: 0.01766 seconds
Time After: 0.02454 seconds
Time Taken: 0.00688 seconds
Time Before: 0.03193 seconds
Time After: 0.03234 seconds
Time Before: 0.03513 seconds
Time After: 0.03634 seconds
Time Before: 0.03123 seconds
Time After: 0.03655 seconds
Time Taken: 0.00532 seconds
Time Before: 0.06687 seconds
Time After: 0.06704 seconds
Time Before: 0.07956 seconds
Time After: 0.08082 seconds
Time Before: 0.09237 seconds
Time After: 0.09258 seconds
Time Before: 0.09596 seconds
Time After: 0.09739 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=140660' WHERE sessionhash = '0d59333b9979c57800f17621ab8164fa'
Time Before: 0.11491 seconds
Time After: 0.11835 seconds
Time Taken: 0.00344 seconds
