Time Before: 0.00873 seconds
Time After: 0.01242 seconds
Time Taken: 0.00369 seconds
Time Before: 0.01251 seconds
Time After: 0.01295 seconds
Time Before: 0.01318 seconds
Time After: 0.01332 seconds
Time Before: 0.01409 seconds
Time After: 0.01626 seconds
Time Taken: 0.00217 seconds
Time Before: 0.01338 seconds
Time After: 0.02017 seconds
Time Taken: 0.00679 seconds
Time Before: 0.02582 seconds
Time After: 0.02628 seconds
Time Before: 0.02871 seconds
Time After: 0.02996 seconds
Time Before: 0.02515 seconds
Time After: 0.03021 seconds
Time Taken: 0.00505 seconds
Time Before: 0.05470 seconds
Time After: 0.05516 seconds
Time Before: 0.06498 seconds
Time After: 0.06625 seconds
End call of global.php: 0.068523168563843
Time Before: 0.07168 seconds
Time After: 0.07186 seconds
Time Before: 0.07448 seconds
Time After: 0.07609 seconds
Time Taken: 0.00161 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=140667', badlocation = 1
Time Before: 0.09229 seconds
Time After: 0.09259 seconds
Page generated in 0.091309070587158 seconds with 9 queries, spending 0.0082876682281494 doing MySQL queries and 0.083021402359009 doing PHP things.
