Time Before: 0.00148 seconds
Time After: 0.00195 seconds
Time Before: 0.00202 seconds
Time After: 0.00244 seconds
Time Before: 0.00265 seconds
Time After: 0.00278 seconds
Time Before: 0.00350 seconds
Time After: 0.00571 seconds
Time Taken: 0.00221 seconds
Time Before: 0.00283 seconds
Time After: 0.00952 seconds
Time Taken: 0.00669 seconds
Time Before: 0.01141 seconds
Time After: 0.01176 seconds
Time Before: 0.01330 seconds
Time After: 0.01450 seconds
Time Before: 0.01086 seconds
Time After: 0.01467 seconds
Time Taken: 0.00381 seconds
Time Before: 0.02079 seconds
Time After: 0.02093 seconds
Time Before: 0.02406 seconds
Time After: 0.02531 seconds
Time Before: 0.02963 seconds
Time After: 0.02979 seconds
Time Before: 0.03208 seconds
Time After: 0.03358 seconds
UPDATE session SET lastactivity = 1783054973, location = '/forums/private.php?do=newpm&explain=1&u=140689', badlocation = 1 WHERE sessionhash = '05bc7c79f91873f78083814ccb7adf41'
Time Before: 0.05195 seconds
Time After: 0.05230 seconds
Memory Before: 4,912.320 KB
Memory After: 4,912.531 KB
