Time Before: 0.01457 seconds
Time After: 0.02036 seconds
Time Taken: 0.00580 seconds
Time Before: 0.02049 seconds
Time After: 0.02100 seconds
Time Before: 0.02124 seconds
Time After: 0.02135 seconds
Time Before: 0.02216 seconds
Time After: 0.02481 seconds
Time Taken: 0.00265 seconds
Time Before: 0.02140 seconds
Time After: 0.02911 seconds
Time Taken: 0.00770 seconds
Time Before: 0.03675 seconds
Time After: 0.03716 seconds
Time Before: 0.04005 seconds
Time After: 0.04121 seconds
Time Taken: 0.00116 seconds
Time Before: 0.03606 seconds
Time After: 0.04143 seconds
Time Taken: 0.00536 seconds
Time Before: 0.07705 seconds
Time After: 0.07719 seconds
REPLACE INTO datastore
(title, data, unserialize)
VALUES
('loadcache', 'a:2:{s:7:\"loadavg\";s:6:\"38.10,\";s:9:\"lastcheck\";i:1785377072;}', 1)Time Before: 0.09435 seconds
Time After: 0.09483 seconds
Memory Before: 3,439.656 KB
Memory After: 3,439.906 KB
Memory Used: 0.250 KB
Time Before: 0.11126 seconds
Time After: 0.11251 seconds
Memory Before: 3,526.469 KB
Memory After: 3,527.063 KB
Time Before: 0.12513 seconds
Time After: 0.12529 seconds
Memory Before: 4,164.406 KB
Memory After: 4,164.836 KB
Time Before: 0.12811 seconds
Time After: 0.12952 seconds
Memory Before: 4,446.055 KB
Memory After: 4,447.742 KB
UPDATE session SET lastactivity = 1785377072, location = '/forums/private.php?do=newpm&explain=1&u=140700' WHERE sessionhash = '5dcfbb55b5add1e7cfb509ae0e835a95'
Time Before: 0.15116 seconds
Time After: 0.15154 seconds
Memory Before: 4,919.781 KB
Memory After: 4,920.008 KB
