Time Before: 0.00229 seconds
Time After: 0.00299 seconds
Time Taken: 0.00071 seconds
Time Before: 0.00310 seconds
Time After: 0.00355 seconds
Time Before: 0.00374 seconds
Time After: 0.00387 seconds
Time Before: 0.00452 seconds
Time After: 0.00705 seconds
Time Taken: 0.00254 seconds
Time Before: 0.00392 seconds
Time After: 0.01243 seconds
Time Taken: 0.00851 seconds
Time Before: 0.01489 seconds
Time After: 0.01543 seconds
Time Taken: 0.00054 seconds
Time Before: 0.01802 seconds
Time After: 0.01927 seconds
Time Before: 0.01412 seconds
Time After: 0.01955 seconds
Time Taken: 0.00543 seconds
Time Before: 0.02657 seconds
Time After: 0.02680 seconds
Time Before: 0.02930 seconds
Time After: 0.03061 seconds
Time Taken: 0.00132 seconds
End call of global.php: 0.032761812210083
Time Before: 0.03428 seconds
Time After: 0.03444 seconds
Time Before: 0.03777 seconds
Time After: 0.03940 seconds
Time Taken: 0.00163 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=140730', badlocation = 1
Time Before: 0.05877 seconds
Time After: 0.05907 seconds
Memory Before: 4,288.203 KB
Memory After: 4,288.430 KB
Page generated in 0.057389974594116 seconds with 9 queries, spending 0.0085601806640625 doing MySQL queries and 0.048829793930054 doing PHP things.
