Time Before: 0.00153 seconds
Time After: 0.00212 seconds
Time Taken: 0.00059 seconds
Time Before: 0.00222 seconds
Time After: 0.00280 seconds
Time Taken: 0.00058 seconds
Time Before: 0.00307 seconds
Time After: 0.00319 seconds
Time Before: 0.00395 seconds
Time After: 0.00660 seconds
Time Taken: 0.00265 seconds
Time Before: 0.00324 seconds
Time After: 0.01100 seconds
Time Taken: 0.00776 seconds
Time Before: 0.01357 seconds
Time After: 0.01407 seconds
Time Before: 0.01648 seconds
Time After: 0.01768 seconds
Time Before: 0.01280 seconds
Time After: 0.01786 seconds
Time Taken: 0.00506 seconds
Time Before: 0.02377 seconds
Time After: 0.02395 seconds
Time Before: 0.02588 seconds
Time After: 0.02717 seconds
Time Before: 0.03100 seconds
Time After: 0.03119 seconds
Time Before: 0.03370 seconds
Time After: 0.03516 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=140742' WHERE sessionhash = '3d710f9993f3eccc4700b01c2edbb01a'
Time Before: 0.04854 seconds
Time After: 0.04882 seconds
