Time Before: 0.02064 seconds
Time After: 0.02597 seconds
Time Taken: 0.00533 seconds
Time Before: 0.02607 seconds
Time After: 0.02673 seconds
Time Taken: 0.00066 seconds
Time Before: 0.02725 seconds
Time After: 0.02740 seconds
Time Before: 0.02831 seconds
Time After: 0.03058 seconds
Time Taken: 0.00228 seconds
Time Before: 0.02746 seconds
Time After: 0.03450 seconds
Time Taken: 0.00703 seconds
Time Before: 0.04250 seconds
Time After: 0.04298 seconds
Time Before: 0.04531 seconds
Time After: 0.04658 seconds
Time Before: 0.04184 seconds
Time After: 0.04685 seconds
Time Taken: 0.00501 seconds
Time Before: 0.09328 seconds
Time After: 0.09343 seconds
Time Before: 0.10531 seconds
Time After: 0.10658 seconds
Time Before: 0.11543 seconds
Time After: 0.11561 seconds
Time Before: 0.11846 seconds
Time After: 0.11992 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=140745', badlocation = 1 WHERE sessionhash = 'cb23636bbd36247f3b1133fdf383bca3'
Time Before: 0.14003 seconds
Time After: 0.14029 seconds
