Time Before: 0.00170 seconds
Time After: 0.00262 seconds
Time Taken: 0.00092 seconds
Time Before: 0.00269 seconds
Time After: 0.00336 seconds
Time Taken: 0.00067 seconds
Time Before: 0.00358 seconds
Time After: 0.00372 seconds
Time Before: 0.00444 seconds
Time After: 0.00689 seconds
Time Taken: 0.00244 seconds
Time Before: 0.00377 seconds
Time After: 0.01051 seconds
Time Taken: 0.00674 seconds
Time Before: 0.01241 seconds
Time After: 0.01281 seconds
Time Before: 0.01518 seconds
Time After: 0.01636 seconds
Time Taken: 0.00118 seconds
Time Before: 0.01172 seconds
Time After: 0.01654 seconds
Time Taken: 0.00482 seconds
Time Before: 0.02197 seconds
Time After: 0.02210 seconds
Time Before: 0.02420 seconds
Time After: 0.02547 seconds
End call of global.php: 0.027979135513306
Time Before: 0.02918 seconds
Time After: 0.02931 seconds
Time Before: 0.03135 seconds
Time After: 0.03279 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=140782'
Time Before: 0.04662 seconds
Time After: 0.04684 seconds
Page generated in 0.045724153518677 seconds with 9 queries, spending 0.0080101490020752 doing MySQL queries and 0.037714004516602 doing PHP things.
