Time Before: 0.01056 seconds
Time After: 0.01285 seconds
Time Taken: 0.00230 seconds
Time Before: 0.01298 seconds
Time After: 0.01349 seconds
Time Before: 0.01373 seconds
Time After: 0.01388 seconds
Time Before: 0.01478 seconds
Time After: 0.01748 seconds
Time Taken: 0.00269 seconds
Time Before: 0.01397 seconds
Time After: 0.02200 seconds
Time Taken: 0.00804 seconds
Time Before: 0.02535 seconds
Time After: 0.02555 seconds
Time Before: 0.02712 seconds
Time After: 0.02839 seconds
Time Before: 0.02453 seconds
Time After: 0.02865 seconds
Time Taken: 0.00412 seconds
Time Before: 0.04349 seconds
Time After: 0.04364 seconds
Time Before: 0.04872 seconds
Time After: 0.05010 seconds
Time Taken: 0.00138 seconds
Time Before: 0.05546 seconds
Time After: 0.05561 seconds
Time Before: 0.05856 seconds
Time After: 0.06014 seconds
Time Taken: 0.00158 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=140801', badlocation = 1 WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.08074 seconds
Time After: 0.08132 seconds
Time Taken: 0.00058 seconds
