Time Before: 0.01552 seconds
Time After: 0.02484 seconds
Time Taken: 0.00932 seconds
Time Before: 0.02495 seconds
Time After: 0.02538 seconds
Time Before: 0.02565 seconds
Time After: 0.02579 seconds
Time Before: 0.02663 seconds
Time After: 0.03017 seconds
Time Taken: 0.00354 seconds
Time Before: 0.02587 seconds
Time After: 0.03399 seconds
Time Taken: 0.00812 seconds
Time Before: 0.04383 seconds
Time After: 0.04418 seconds
Time Before: 0.04692 seconds
Time After: 0.04813 seconds
Memory Before: 2,148.953 KB
Memory After: 2,148.813 KB
Time Before: 0.04322 seconds
Time After: 0.04839 seconds
Time Taken: 0.00516 seconds
Memory After: 2,261.836 KB
Time Before: 0.07097 seconds
Time After: 0.07110 seconds
Memory Before: 2,815.359 KB
Memory After: 2,815.875 KB
Time Before: 1.31589 seconds
Time After: 1.31796 seconds
Time Taken: 0.00206 seconds
Memory Before: 2,903.570 KB
Memory After: 2,904.164 KB
End call of global.php: 1.3207249641418
Time Before: 1.32747 seconds
Time After: 1.32768 seconds
Memory Before: 3,540.344 KB
Memory After: 3,540.773 KB
Time Before: 1.33033 seconds
Time After: 1.33208 seconds
Time Taken: 0.00174 seconds
Memory Before: 3,821.906 KB
Memory After: 3,823.594 KB
SET lastactivity = 1788935907, location = '/forums/private.php?do=newpm&explain=1&u=14081'
Time Before: 1.35006 seconds
Time After: 1.35039 seconds
Memory Before: 4,287.578 KB
Memory After: 4,287.805 KB
Page generated in 1.3490369319916 seconds with 9 queries, spending 0.010152816772461 doing MySQL queries and 1.3388841152191 doing PHP things.
