Time Before: 0.01971 seconds
Time After: 0.02889 seconds
Time Taken: 0.00918 seconds
Time Before: 0.02900 seconds
Time After: 0.03051 seconds
Time Taken: 0.00151 seconds
Time Before: 0.03093 seconds
Time After: 0.03110 seconds
Time Before: 0.03185 seconds
Time After: 0.03423 seconds
Time Taken: 0.00238 seconds
Time Before: 0.03117 seconds
Time After: 0.03975 seconds
Time Taken: 0.00857 seconds
Time Before: 0.04675 seconds
Time After: 0.04728 seconds
Time Taken: 0.00053 seconds
Time Before: 0.05073 seconds
Time After: 0.05372 seconds
Time Taken: 0.00299 seconds
Time Before: 0.04598 seconds
Time After: 0.05394 seconds
Time Taken: 0.00797 seconds
Time Before: 0.07990 seconds
Time After: 0.08009 seconds
Time Before: 0.11358 seconds
Time After: 0.11491 seconds
Time Taken: 0.00134 seconds
Time Before: 0.12762 seconds
Time After: 0.12785 seconds
Time Before: 0.13131 seconds
Time After: 0.13281 seconds
UPDATE session SET lastactivity = 1788932412, location = '/forums/private.php?do=newpm&explain=1&u=140825', badlocation = 1 WHERE sessionhash = '7fe2d67a1fab00498787d8dbbdf69797'
Time Before: 0.15129 seconds
Time After: 0.15166 seconds
Memory Before: 4,912.320 KB
Memory After: 4,912.531 KB
