Time Before: 0.02693 seconds
Time After: 0.03441 seconds
Time Taken: 0.00749 seconds
Time Before: 0.03450 seconds
Time After: 0.03496 seconds
Time Before: 0.03521 seconds
Time After: 0.03534 seconds
Time Before: 0.03615 seconds
Time After: 0.03837 seconds
Time Taken: 0.00222 seconds
Time Before: 0.03540 seconds
Time After: 0.04301 seconds
Time Taken: 0.00761 seconds
Time Before: 0.05308 seconds
Time After: 0.05352 seconds
Time Before: 0.05533 seconds
Time After: 0.05732 seconds
Time Taken: 0.00200 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.05182 seconds
Time After: 0.05762 seconds
Time Taken: 0.00580 seconds
Memory After: 2,261.820 KB
Time Before: 0.09828 seconds
Time After: 0.09932 seconds
Time Taken: 0.00104 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.12098 seconds
Time After: 0.12246 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
End call of global.php: 0.12484502792358
Time Before: 0.13340 seconds
Time After: 0.13383 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.13685 seconds
Time After: 0.13833 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
SET lastactivity = 1788946332, location = '/forums/private.php?do=newpm&explain=1&u=140866', badlocation = 1
Time Before: 0.15712 seconds
Time After: 0.15774 seconds
Time Taken: 0.00062 seconds
Memory Before: 4,287.836 KB
Memory After: 4,288.047 KB
Page generated in 0.15595483779907 seconds with 9 queries, spending 0.010298252105713 doing MySQL queries and 0.14565658569336 doing PHP things.
