Time Before: 0.00199 seconds
Time After: 0.00257 seconds
Time Taken: 0.00059 seconds
Time Before: 0.00271 seconds
Time After: 0.00310 seconds
Time Before: 0.00338 seconds
Time After: 0.00355 seconds
Time Before: 0.00425 seconds
Time After: 0.00655 seconds
Time Taken: 0.00230 seconds
Time Before: 0.00367 seconds
Time After: 0.01000 seconds
Time Taken: 0.00633 seconds
Time Before: 0.01165 seconds
Time After: 0.01196 seconds
Time Before: 0.01312 seconds
Time After: 0.01433 seconds
Time Before: 0.01113 seconds
Time After: 0.01450 seconds
Time Taken: 0.00338 seconds
Time Before: 0.01959 seconds
Time After: 0.01971 seconds
Time Before: 0.02153 seconds
Time After: 0.02275 seconds
End call of global.php: 0.024479150772095
Time Before: 0.02551 seconds
Time After: 0.02574 seconds
Time Before: 0.02769 seconds
Time After: 0.02910 seconds
SET lastactivity = 1784873652, location = '/forums/private.php?do=newpm&explain=1&u=140877'
WHERE sessionhash = 'b773d1d737f443efcc9fdfe9a9930185'
Time Before: 0.04194 seconds
Time After: 0.04229 seconds
Page generated in 0.040980100631714 seconds with 9 queries, spending 0.0077090263366699 doing MySQL queries and 0.033271074295044 doing PHP things.
