Time Before: 0.01468 seconds
Time After: 0.02101 seconds
Time Taken: 0.00633 seconds
Time Before: 0.02111 seconds
Time After: 0.02163 seconds
Time Before: 0.02187 seconds
Time After: 0.02202 seconds
Time Before: 0.02276 seconds
Time After: 0.02529 seconds
Time Taken: 0.00253 seconds
Time Before: 0.02207 seconds
Time After: 0.02927 seconds
Time Taken: 0.00720 seconds
Time Before: 0.03583 seconds
Time After: 0.03636 seconds
Time Taken: 0.00054 seconds
Time Before: 0.03905 seconds
Time After: 0.04026 seconds
Time Before: 0.03517 seconds
Time After: 0.04057 seconds
Time Taken: 0.00540 seconds
Time Before: 0.06592 seconds
Time After: 0.06605 seconds
Time Before: 0.07952 seconds
Time After: 0.08074 seconds
Time Before: 0.08893 seconds
Time After: 0.08911 seconds
Time Before: 0.09229 seconds
Time After: 0.09376 seconds
UPDATE session SET lastactivity = 1784729599, location = '/forums/private.php?do=newpm&explain=1&u=140881', badlocation = 1 WHERE sessionhash = 'b910b85238c3231bdc641e11d90490dd'
Time Before: 0.11180 seconds
Time After: 0.11226 seconds
Memory Before: 4,288.547 KB
Memory After: 4,288.758 KB
