Time Before: 0.00606 seconds
Time After: 0.00858 seconds
Time Taken: 0.00252 seconds
Time Before: 0.00872 seconds
Time After: 0.00913 seconds
Time Before: 0.00934 seconds
Time After: 0.00951 seconds
Time Before: 0.01031 seconds
Time After: 0.01280 seconds
Time Taken: 0.00249 seconds
Time Before: 0.00957 seconds
Time After: 0.01866 seconds
Time Taken: 0.00909 seconds
Time Before: 0.02180 seconds
Time After: 0.02222 seconds
Time Before: 0.02491 seconds
Time After: 0.02612 seconds
Time Before: 0.02111 seconds
Time After: 0.02635 seconds
Time Taken: 0.00525 seconds
Time Before: 0.03655 seconds
Time After: 0.03672 seconds
Time Before: 0.04144 seconds
Time After: 0.04272 seconds
End call of global.php: 0.045032978057861
Time Before: 0.04734 seconds
Time After: 0.04748 seconds
Time Before: 0.05030 seconds
Time After: 0.05180 seconds
Time Taken: 0.00150 seconds
SET lastactivity = 1788875887, location = '/forums/private.php?do=newpm&explain=1&u=141023'
Time Before: 0.07209 seconds
Time After: 0.07239 seconds
Page generated in 0.070630073547363 seconds with 9 queries, spending 0.0080933570861816 doing MySQL queries and 0.062536716461182 doing PHP things.
