Time Before: 0.00321 seconds
Time After: 0.00453 seconds
Time Taken: 0.00132 seconds
Time Before: 0.00463 seconds
Time After: 0.00530 seconds
Time Taken: 0.00067 seconds
Time Before: 0.00554 seconds
Time After: 0.00567 seconds
Time Before: 0.00635 seconds
Time After: 0.00851 seconds
Time Taken: 0.00217 seconds
Time Before: 0.00572 seconds
Time After: 0.01194 seconds
Time Taken: 0.00623 seconds
Time Before: 0.01417 seconds
Time After: 0.01455 seconds
Time Before: 0.01619 seconds
Time After: 0.01742 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.01334 seconds
Time After: 0.01768 seconds
Time Taken: 0.00434 seconds
Memory After: 2,261.820 KB
Time Before: 0.02859 seconds
Time After: 0.02875 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.03478 seconds
Time After: 0.03600 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
Time Before: 0.03935 seconds
Time After: 0.03951 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.04251 seconds
Time After: 0.04396 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
UPDATE session SET lastactivity = 1789137304, location = '/forums/private.php?do=newpm&explain=1&u=141038', badlocation = 1 WHERE sessionhash = '2e9a27470c1bd6d04caedfc611bd3cf4'
Time Before: 0.06480 seconds
Time After: 0.06514 seconds
Memory Before: 4,288.641 KB
Memory After: 4,288.852 KB
