Time Before: 0.01444 seconds
Time After: 0.02186 seconds
Time Taken: 0.00742 seconds
Time Before: 0.02199 seconds
Time After: 0.02249 seconds
Time Before: 0.02275 seconds
Time After: 0.02291 seconds
Time Before: 0.02364 seconds
Time After: 0.02593 seconds
Time Taken: 0.00229 seconds
Time Before: 0.02297 seconds
Time After: 0.03057 seconds
Time Taken: 0.00760 seconds
Time Before: 0.03716 seconds
Time After: 0.03757 seconds
Time Before: 0.04014 seconds
Time After: 0.04133 seconds
Time Before: 0.03645 seconds
Time After: 0.04156 seconds
Time Taken: 0.00511 seconds
Time Before: 0.07248 seconds
Time After: 0.07264 seconds
Time Before: 0.08395 seconds
Time After: 0.08516 seconds
Time Before: 0.09426 seconds
Time After: 0.09446 seconds
Time Before: 0.09699 seconds
Time After: 0.09844 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=141048' WHERE sessionhash = 'f9921609250f226198462d57df303337'
Time Before: 0.11686 seconds
Time After: 0.11710 seconds
