Time Before: 0.03226 seconds
Time After: 0.04150 seconds
Time Taken: 0.00924 seconds
Time Before: 0.04159 seconds
Time After: 0.04203 seconds
Time Before: 0.04227 seconds
Time After: 0.04243 seconds
Time Before: 0.04320 seconds
Time After: 0.04562 seconds
Time Taken: 0.00242 seconds
Time Before: 0.04249 seconds
Time After: 0.05004 seconds
Time Taken: 0.00755 seconds
Time Before: 0.06128 seconds
Time After: 0.06175 seconds
Time Before: 0.06473 seconds
Time After: 0.06609 seconds
Time Taken: 0.00136 seconds
Time Before: 0.06051 seconds
Time After: 0.06627 seconds
Time Taken: 0.00576 seconds
Time Before: 0.11296 seconds
Time After: 0.11332 seconds
Time Before: 0.13259 seconds
Time After: 0.13389 seconds
Time Taken: 0.00131 seconds
Time Before: 0.14490 seconds
Time After: 0.14506 seconds
Time Before: 0.14771 seconds
Time After: 0.14914 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=141061', badlocation = 1 WHERE sessionhash = '87651ca345a619a09949038b7f47c9ec'
Time Before: 0.16884 seconds
Time After: 0.16916 seconds
Memory Before: 4,288.203 KB
Memory After: 4,288.430 KB
