Time Before: 0.00202 seconds
Time After: 0.00262 seconds
Time Taken: 0.00060 seconds
Time Before: 0.00273 seconds
Time After: 0.00320 seconds
Time Before: 0.00348 seconds
Time After: 0.00381 seconds
Time Before: 0.00468 seconds
Time After: 0.00706 seconds
Time Taken: 0.00237 seconds
Time Before: 0.00389 seconds
Time After: 0.01202 seconds
Time Taken: 0.00813 seconds
Time Before: 0.01430 seconds
Time After: 0.01451 seconds
Time Before: 0.01724 seconds
Time After: 0.01843 seconds
Time Taken: 0.00118 seconds
Time Before: 0.01357 seconds
Time After: 0.01870 seconds
Time Taken: 0.00514 seconds
Time Before: 0.02431 seconds
Time After: 0.02448 seconds
Time Before: 0.02639 seconds
Time After: 0.02762 seconds
Time Before: 0.03183 seconds
Time After: 0.03202 seconds
Time Before: 0.03526 seconds
Time After: 0.03672 seconds
UPDATE session SET lastactivity = 1783505936, location = '/forums/private.php?do=newpm&explain=1&u=141176', badlocation = 1 WHERE sessionhash = 'f88c536979e48fd20a608e8efaf90f77'
Time Before: 0.05493 seconds
Time After: 0.05529 seconds
