Time Before: 0.01326 seconds
Time After: 0.01574 seconds
Time Taken: 0.00248 seconds
Time Before: 0.01585 seconds
Time After: 0.01635 seconds
Time Before: 0.01660 seconds
Time After: 0.01672 seconds
Time Before: 0.01742 seconds
Time After: 0.01990 seconds
Time Taken: 0.00249 seconds
Time Before: 0.01677 seconds
Time After: 0.02424 seconds
Time Taken: 0.00747 seconds
Time Before: 0.03005 seconds
Time After: 0.03035 seconds
Time Before: 0.03295 seconds
Time After: 0.03436 seconds
Time Before: 0.02937 seconds
Time After: 0.03455 seconds
Time Taken: 0.00518 seconds
Time Before: 0.06311 seconds
Time After: 0.06325 seconds
Time Before: 0.07329 seconds
Time After: 0.07463 seconds
Time Taken: 0.00133 seconds
End call of global.php: 0.077171087265015
Time Before: 0.08140 seconds
Time After: 0.08156 seconds
Time Before: 0.08398 seconds
Time After: 0.08540 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=141189', badlocation = 1
WHERE sessionhash = '295cc732df117534f65c11ae631a16f6'
Time Before: 0.10196 seconds
Time After: 0.10226 seconds
Page generated in 0.1009418964386 seconds with 9 queries, spending 0.0081655979156494 doing MySQL queries and 0.092776298522949 doing PHP things.
