Time Before: 0.01399 seconds
Time After: 0.01864 seconds
Time Taken: 0.00465 seconds
Time Before: 0.01871 seconds
Time After: 0.01918 seconds
Time Before: 0.01940 seconds
Time After: 0.01955 seconds
Time Before: 0.02038 seconds
Time After: 0.02275 seconds
Time Taken: 0.00237 seconds
Time Before: 0.01961 seconds
Time After: 0.02693 seconds
Time Taken: 0.00731 seconds
Time Before: 0.03236 seconds
Time After: 0.03279 seconds
Time Before: 0.03509 seconds
Time After: 0.03641 seconds
Time Taken: 0.00132 seconds
Time Before: 0.03165 seconds
Time After: 0.03663 seconds
Time Taken: 0.00498 seconds
Time Before: 0.06857 seconds
Time After: 0.06870 seconds
Time Before: 0.08365 seconds
Time After: 0.08507 seconds
End call of global.php: 0.087196111679077
Time Before: 0.09161 seconds
Time After: 0.09175 seconds
Time Before: 0.09433 seconds
Time After: 0.09584 seconds
Time Taken: 0.00151 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=141206', badlocation = 1
WHERE sessionhash = 'b1e9f976e3e130f3a0e1c3e688e54b68'
Time Before: 0.11558 seconds
Time After: 0.11583 seconds
Page generated in 0.11458611488342 seconds with 9 queries, spending 0.0082013607025146 doing MySQL queries and 0.10638475418091 doing PHP things.
