Time Before: 0.00581 seconds
Time After: 0.00666 seconds
Time Taken: 0.00085 seconds
Time Before: 0.00677 seconds
Time After: 0.00721 seconds
Time Before: 0.00753 seconds
Time After: 0.00768 seconds
Time Before: 0.00858 seconds
Time After: 0.01089 seconds
Time Taken: 0.00231 seconds
Time Before: 0.00775 seconds
Time After: 0.01580 seconds
Time Taken: 0.00805 seconds
Time Before: 0.01900 seconds
Time After: 0.01940 seconds
Time Before: 0.02203 seconds
Time After: 0.02332 seconds
Time Before: 0.01827 seconds
Time After: 0.02355 seconds
Time Taken: 0.00528 seconds
Time Before: 0.04058 seconds
Time After: 0.04074 seconds
Time Before: 0.04824 seconds
Time After: 0.04954 seconds
Time Before: 0.05596 seconds
Time After: 0.05614 seconds
Time Before: 0.05869 seconds
Time After: 0.06017 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=141244' WHERE sessionhash = '90b3c67278b177629fe550ebf4d83bbe'
Time Before: 0.07661 seconds
Time After: 0.07687 seconds
