Time Before: 0.01768 seconds
Time After: 0.02149 seconds
Time Taken: 0.00381 seconds
Time Before: 0.02160 seconds
Time After: 0.02205 seconds
Time Before: 0.02230 seconds
Time After: 0.02244 seconds
Time Before: 0.02324 seconds
Time After: 0.02597 seconds
Time Taken: 0.00273 seconds
Time Before: 0.02252 seconds
Time After: 0.03020 seconds
Time Taken: 0.00768 seconds
Time Before: 0.03669 seconds
Time After: 0.03713 seconds
Time Before: 0.03967 seconds
Time After: 0.04091 seconds
Time Before: 0.03595 seconds
Time After: 0.04118 seconds
Time Taken: 0.00522 seconds
Time Before: 0.06827 seconds
Time After: 0.06846 seconds
Time Before: 0.08173 seconds
Time After: 0.08300 seconds
Time Before: 0.09283 seconds
Time After: 0.09301 seconds
Time Before: 0.09531 seconds
Time After: 0.09675 seconds
UPDATE session SET lastactivity = 1783256283, location = '/forums/private.php?do=newpm&explain=1&u=141262', badlocation = 1 WHERE sessionhash = '19bddeacfb649beeea65b05d036d70bd'
Time Before: 0.11414 seconds
Time After: 0.11442 seconds
