Time Before: 0.00162 seconds
Time After: 0.00260 seconds
Time Taken: 0.00097 seconds
Time Before: 0.00267 seconds
Time After: 0.00434 seconds
Time Taken: 0.00167 seconds
Time Before: 0.00463 seconds
Time After: 0.00485 seconds
Time Before: 0.00559 seconds
Time After: 0.00787 seconds
Time Taken: 0.00228 seconds
Time Before: 0.00491 seconds
Time After: 0.01134 seconds
Time Taken: 0.00643 seconds
Time Before: 0.01321 seconds
Time After: 0.01362 seconds
Time Before: 0.01670 seconds
Time After: 0.01792 seconds
Time Before: 0.01257 seconds
Time After: 0.01809 seconds
Time Taken: 0.00552 seconds
Time Before: 0.02355 seconds
Time After: 0.02372 seconds
Time Before: 0.02586 seconds
Time After: 0.02707 seconds
Time Before: 0.03054 seconds
Time After: 0.03074 seconds
Time Before: 0.03299 seconds
Time After: 0.03452 seconds
Time Taken: 0.00153 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=141324' WHERE sessionhash = '05469e5b46550d3cbf9ccd27256b5c39'
Time Before: 0.04966 seconds
Time After: 0.05002 seconds
