Time Before: 0.00225 seconds
Time After: 0.00299 seconds
Time Taken: 0.00074 seconds
Time Before: 0.00309 seconds
Time After: 0.00357 seconds
Time Before: 0.00383 seconds
Time After: 0.00401 seconds
Time Before: 0.00495 seconds
Time After: 0.00767 seconds
Time Taken: 0.00272 seconds
Time Before: 0.00409 seconds
Time After: 0.01185 seconds
Time Taken: 0.00776 seconds
Time Before: 0.01383 seconds
Time After: 0.01431 seconds
Time Before: 0.01593 seconds
Time After: 0.01711 seconds
Time Taken: 0.00118 seconds
Time Before: 0.01311 seconds
Time After: 0.01736 seconds
Time Taken: 0.00424 seconds
Time Before: 0.02316 seconds
Time After: 0.02336 seconds
Time Before: 0.02528 seconds
Time After: 0.02658 seconds
End call of global.php: 0.028321981430054
Time Before: 0.02971 seconds
Time After: 0.02986 seconds
Time Before: 0.03245 seconds
Time After: 0.03391 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=141405', badlocation = 1
Time Before: 0.04893 seconds
Time After: 0.04929 seconds
Memory Before: 4,288.203 KB
Memory After: 4,288.430 KB
Page generated in 0.047982931137085 seconds with 9 queries, spending 0.0085036754608154 doing MySQL queries and 0.03947925567627 doing PHP things.
