Time Before: 0.00147 seconds
Time After: 0.00192 seconds
Time Before: 0.00200 seconds
Time After: 0.00248 seconds
Time Before: 0.00271 seconds
Time After: 0.00286 seconds
Time Before: 0.00360 seconds
Time After: 0.00664 seconds
Time Taken: 0.00304 seconds
Time Before: 0.00293 seconds
Time After: 0.01177 seconds
Time Taken: 0.00884 seconds
Time Before: 0.01383 seconds
Time After: 0.01422 seconds
Time Before: 0.01672 seconds
Time After: 0.01925 seconds
Time Taken: 0.00253 seconds
Time Before: 0.01320 seconds
Time After: 0.01943 seconds
Time Taken: 0.00624 seconds
Time Before: 0.02571 seconds
Time After: 0.02584 seconds
Time Before: 1.49354 seconds
Time After: 1.49564 seconds
Time Taken: 0.00210 seconds
End call of global.php: 1.4983410835266
Time Before: 1.49981 seconds
Time After: 1.49997 seconds
Time Before: 1.50268 seconds
Time After: 1.50432 seconds
Time Taken: 0.00164 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=141441', badlocation = 1
Time Before: 1.51863 seconds
Time After: 1.51893 seconds
Page generated in 1.5175790786743 seconds with 9 queries, spending 0.010913133621216 doing MySQL queries and 1.5066659450531 doing PHP things.
